주요 콘텐츠로 건너뛰기
Toshiba Satellite C675-S7106 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C675-S7106 Keyboard Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 4 단계, 이미지 3/3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: 5 단계, 이미지 1/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 5 단계, 이미지 2/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 5 단계, 이미지 3/3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: 6 단계, 이미지 1/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 6 단계, 이미지 2/3 Toshiba Satellite C675-S7106 Keyboard Replacement: 6 단계, 이미지 3/3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
결론
Dinis Valcorba
회원 가입일: 03/26/19
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 461
