주요 콘텐츠로 건너뛰기
Toshiba Satellite C675-S7106 RAM Replacement
필요한 것
  1. Toshiba Satellite C675-S7106 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C675-S7106 RAM Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 RAM Replacement, RAM: 3 단계, 이미지 1/2 Toshiba Satellite C675-S7106 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0 head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C675-S7106 RAM Replacement: 4 단계, 이미지 2/2
    • Unclip and move the two metal clips on either side of one or either RAM stick.
    • Pull the stick outwards as you lift it upwards.
    • When reinstalling, ensure that the contacts are completely covered and connected.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Steakelum
회원 가입일: 03/25/19
451 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 244
