주요 콘텐츠로 건너뛰기
Toshiba Satellite C75D-A7370 Battery Replacement
필요한 것
  1. Toshiba Satellite C75D-A7370 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C75D-A7370 Battery Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Battery Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C75D-A7370 Battery Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C75D-A7370 Battery Replacement: 3 단계, 이미지 3/3
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
결론
Chris Purdie
회원 가입일: 02/02/17
428 평판
안내서 4개 작성하였습니다
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 595
