주요 콘텐츠로 건너뛰기
Toshiba Satellite C75D-A7370 Hard-Drive Replacement
필요한 것
  1. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 3 단계, 이미지 3/3
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 4 단계, 이미지 1/3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 4 단계, 이미지 2/3 Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Back Access Panel: 4 단계, 이미지 3/3
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
  5. Toshiba Satellite C75D-A7370 Hard-Drive Replacement, Hard-Drive: 5 단계, 이미지 1/1
    • Locate the hard-drive.
  6. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 6 단계, 이미지 2/2
    • Remove the two 7 mm screws holding the hard-drive in place with a P1 driver
  7. Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite C75D-A7370 Hard-Drive Replacement: 7 단계, 이미지 2/2
    • Then using the tab located on top of the hard-drive pull up towards you and then pull to the left to disconnect the hard-drive. Now you are ready to replace your hard-drive.
결론
Basim Ismail
회원 가입일: 02/02/17
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 18
전체 시간: 2,006
