주요 콘텐츠로 건너뛰기
Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
필요한 것
동영상 개요
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: 1 단계, 이미지 1/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: 1 단계, 이미지 2/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: 1 단계, 이미지 3/3
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 2 단계, 이미지 3/3
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 3 단계, 이미지 3/3
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: 4 단계, 이미지 2/2
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,507 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,488개 작성하였습니다
댓글 3개
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - 답글
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 56
전체 시간: 8,109
