소개
You might need to replace your CMOS (Complementary Metal Oxide Semiconductor) battery if your Toshiba laptop is losing its time and date settings or if you are receiving a CMOS error message. You will also need to remove your CMOS before replacing other elements, such as the motherboard.
필요한 것
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
다른 2명이 해당 안내서를 완성하였습니다.
