주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Keeping your laptop cool is important to the speed and functionality of the device. This guide will show you how to replace your Toshiba's cooling fans.
부품
지정된 부품이 없습니다.
  1. Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery. Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver. Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver. Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Insert a plastic opening tool and follow the edges to open the panel. Insert a plastic opening tool and follow the edges to open the panel. Insert a plastic opening tool and follow the edges to open the panel.
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Remove the three 3.5mm Phillips #1 screws indicated in the picture.
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker. Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker. Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Pull the HDD out.
    • Pull the HDD out.
  9. Insert a plastic opening tool in between the panel and the main assembly.
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Work your way around the laptop to remove the base plate.
    • Work your way around the laptop to remove the base plate.
  11. Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Gently pull out the two pin connector.
    • Gently pull out the two pin connector.
  13. Remove the CPU fan.
    • Remove the CPU fan.
결론
Claire Fletcher
회원 가입일: 2018년 04월 05일
937 평판
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 46
전체 시간: 609
