이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
Insert a plastic opening tool in between the panel and the main assembly.
Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
다른 2명이 해당 안내서를 완성하였습니다.
