주요 콘텐츠로 건너뛰기
Toshiba Satellite C855-S5115 DVD Tray Replacement
필요한 것
  1. Toshiba Satellite C855-S5115 DVD Tray Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  2. Toshiba Satellite C855-S5115 DVD Tray Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C855-S5115 DVD Tray Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C855-S5115 DVD Tray Replacement: 2 단계, 이미지 3/3
    • Pry the back panel out of the laptop using the spudger tool
  3. Toshiba Satellite C855-S5115 DVD Tray Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C855-S5115 DVD Tray Replacement: 3 단계, 이미지 2/2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  4. Toshiba Satellite C855-S5115 DVD Tray Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C855-S5115 DVD Tray Replacement: 4 단계, 이미지 2/2
    • Slide the HDD towards the sticker on the left.
  5. Toshiba Satellite C855-S5115 DVD Tray Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C855-S5115 DVD Tray Replacement: 5 단계, 이미지 2/2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
  6. Toshiba Satellite C855-S5115 DVD Tray Replacement, DVD Tray: 6 단계, 이미지 1/1
    • Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
  7. Toshiba Satellite C855-S5115 DVD Tray Replacement: 7 단계, 이미지 1/2 Toshiba Satellite C855-S5115 DVD Tray Replacement: 7 단계, 이미지 2/2
    • Insert a plastic opening tool and follow the edges to open the panel.
  8. Toshiba Satellite C855-S5115 DVD Tray Replacement: 8 단계, 이미지 1/1
    • Once open, locate the CD tray indicated in this picture.
  9. Toshiba Satellite C855-S5115 DVD Tray Replacement: 9 단계, 이미지 1/2 Toshiba Satellite C855-S5115 DVD Tray Replacement: 9 단계, 이미지 2/2
    • Lift the tray up and out.
결론
Claire Fletcher
회원 가입일: 04/05/18
964 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 272
