주요 콘텐츠로 건너뛰기
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
필요한 것
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 2 단계, 이미지 1/1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 4 단계, 이미지 3/3
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 5 단계, 이미지 2/2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 6 단계, 이미지 2/2
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: 7 단계, 이미지 2/2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
결론
Claire Fletcher
회원 가입일: 04/05/18
964 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 1,312
