소개
Sticking and broken keys means it might be time for a new keyboard. This guide will show you how to remove and replace you Toshiba's keyboard.
도구
부품
지정된 부품이 없습니다.
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
거의 끝나갑니다!
결론
댓글 2개
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
