주요 콘텐츠로 건너뛰기
Toshiba Satellite C855-S5115 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: 2 단계, 이미지 1/1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Keyboard Replacement: 4 단계, 이미지 2/2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C855-S5115 Keyboard Replacement: 5 단계, 이미지 2/2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Claire Fletcher
회원 가입일: 04/05/18
964 평판
안내서 7개 작성하였습니다
댓글 2개
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - 답글
Do you have to do anything with the connector before removing?
William - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 33
전체 시간: 2,555
