이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
Pull out the connector attaching the keyboard to the main body of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
