주요 콘텐츠로 건너뛰기
Toshiba Satellite C855D-S5109 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C855D-S5109 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C855D-S5109 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C855D-S5109 Hard Drive Replacement: 3 단계, 이미지 3/3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
결론
Rebeca Carrillo
회원 가입일: 09/30/21
87 평판
안내서 1개 작성함
Casper College, Team 1-3, Lareau Fall 2021 Casper College, Team 1-3, Lareau Fall 2021 회원
CASC-LAREAU-F21S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 13
전체 시간: 173
