주요 콘텐츠로 건너뛰기
Toshiba Satellite C855D-S5109 RAM Replacement
필요한 것
  1. Toshiba Satellite C855D-S5109 RAM Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C855D-S5109 RAM Replacement: 2 단계, 이미지 2/2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C855D-S5109 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C855D-S5109 RAM Replacement: 3 단계, 이미지 3/3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Flip the laptop around so that the bottom is facing you.
  5. Toshiba Satellite C855D-S5109 RAM Replacement: 5 단계, 이미지 1/1
    • Unscrew the Phillips #00 screw, and remove the back cover.
  6. Toshiba Satellite C855D-S5109 RAM Replacement: 6 단계, 이미지 1/1
    • Spread the metal clamps on either side of the RAM card outward so the RAM pops up.
  7. Toshiba Satellite C855D-S5109 RAM Replacement: 7 단계, 이미지 1/1
    • Pull the RAM out of the slot in a horizontal direction.
    • Be sure to only handle the edges of the RAM card, as the oils on your fingers can cause damage if they make contact with the face of the card.
결론
Kaia Herrera
회원 가입일: 02/26/21
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 157
