주요 콘텐츠로 건너뛰기
Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C855D-S5303 Battery Replacement: 2 단계, 이미지 2/2
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: 3 단계, 이미지 1/1
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C855D-S5303 Battery Replacement: 4 단계, 이미지 2/2
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: 5 단계, 이미지 1/1
    • The battery can now be pulled out entirely. You are ready to replace it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Courtney Burns
회원 가입일: 10/20/16
836 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 995
