소개
This guide will show you how to remove your laptops battery. This process requires no tools; just your hands! When doing this, make sure that the device is powered off and not hot from recent usage.
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
