주요 콘텐츠로 건너뛰기
Toshiba Satellite C855D-S5303 Disc Drive Replacement
필요한 것
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 1 단계, 이미지 1/3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 1 단계, 이미지 2/3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: 1 단계, 이미지 3/3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: 2 단계, 이미지 1/1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: 3 단계, 이미지 2/2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Courtney Burns
회원 가입일: 10/20/16
836 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 8
전체 시간: 355
