소개
This guide will show you how to replace your laptops fan. This process requires only a small Phillips head screwdriver and your hands.
필요한 것
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
