주요 콘텐츠로 건너뛰기
Toshiba Satellite C855D-S5303 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C855D-S5303 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
  2. Toshiba Satellite C855D-S5303 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C855D-S5303 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be careful while removing the panel. Don't apply too much force when lifting as you may crack the plastic.
  3. Toshiba Satellite C855D-S5303 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite C855D-S5303 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Locate the hard drive. It is in a metal casing as pictured.
    • To remove, grab the right side of the piece and slide leftwards.
    • Lift up and out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Courtney Burns
회원 가입일: 10/20/16
836 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,631
