주요 콘텐츠로 건너뛰기
Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out carefully using two hands.
결론
작성자
2다른 기여자 명과 함께
Emma King
회원 가입일: 09/04/19
334 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 26
전체 시간: 858
