주요 콘텐츠로 건너뛰기
Toshiba Satellite C875-S7304 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 Hard Drive Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 Hard Drive Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 Hard Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Pull the hard drive laterally to disconnect it from the laptop.
    • Use the clear tab to lift the hard drive out of the laptop.
    • When reassembling, make sure the hard drive lies flat in the laptop before reconnecting it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Taimoor Arshad
회원 가입일: 09/04/19
408 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 1,539
