주요 콘텐츠로 건너뛰기
Toshiba Satellite C875-S7304 RAM Replacement
필요한 것
  1. Toshiba Satellite C875-S7304 RAM Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 RAM Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 RAM Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 RAM Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 RAM Replacement, RAM: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 RAM Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 RAM Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 RAM Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 RAM Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Push outward on the metal tabs to unclasp the RAM from its slot.
    • With the RAM unclasped at a slight angle, carefully pull it out with two hands.
    • When reassembling, remember to align the indentation on the RAM with the indentation on its slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Taimoor Arshad
회원 가입일: 09/04/19
408 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 27
전체 시간: 1,285
