주요 콘텐츠로 건너뛰기
Toshiba Satellite CL15t-B1204X Motherboard Replacement
필요한 것
  1. Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 3 단계, 이미지 1/1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 5 단계, 이미지 1/1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 6 단계, 이미지 1/1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Unscrew the four 3mm screws with the PH1 screw head, on the corner of the heatsink.
  8. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 8 단계, 이미지 1/1
    • Carefully remove the Heatsink from the board.
  9. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 9 단계, 이미지 1/2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 9 단계, 이미지 2/2
    • Unplug all 5 Ribbon cables connecting the motherboard.
  10. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 10 단계, 이미지 1/2 Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 10 단계, 이미지 2/2
    • Unscrew the seven 3mm screws with the PH1 screw head, which are surrounded by a red circle to make identification easier, from the motherboard.
  11. Toshiba Satellite CL15t-B1204X  Motherboard Replacement: 11 단계, 이미지 1/1
    • Carefully pick up and remove the motherboard.
결론
Royce Alexander Porter
회원 가입일: 09/10/18
661 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 652
