주요 콘텐츠로 건너뛰기
Toshiba Satellite CL15t-B1204X Speaker Replacement
필요한 것
  1. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 2 단계, 이미지 1/1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 3 단계, 이미지 1/1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 5 단계, 이미지 1/1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 6 단계, 이미지 1/1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: 7 단계, 이미지 1/2 Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: 7 단계, 이미지 2/2
    • Carefully unplug the speaker's cord from the I/O board.
  8. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 8 단계, 이미지 1/2 Toshiba Satellite CL15t-B1204X  Speaker Replacement: 8 단계, 이미지 2/2
    • Unscrew the two 3mm screws with the PH1 screw head on each speaker found on the corner's away from the hinges.
  9. Toshiba Satellite CL15t-B1204X  Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the speakers.
결론
Royce Alexander Porter
회원 가입일: 09/10/18
661 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 189
