주요 콘텐츠로 건너뛰기
Toshiba Satellite Click 2 L35W-B3204 Screen Replacement
필요한 것
  1. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: 1 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: 1 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 2 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 2 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 2 단계, 이미지 3/3
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 3 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 3 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 3 단계, 이미지 3/3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: 4 단계, 이미지 1/1
    • Your screen is now completely detached from the internal components.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lexi Lannigan
회원 가입일: 10/17/18
753 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 UMass Dartmouth, Team S1-G4, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G4
6 회원들
안내서 12개 작성하였습니다
댓글 한 개
This instruction set was VERY useful, since it focused on the exact device that I have, and had great photos to accompany the steps. TC
Thomas Cirillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 1,514
