소개
If your laptop does not respond to touch, or has issues with the display, this guide will help you replace the screen.This guide does not involve the keyboard portion of the laptop, so remove the keyboard from the screen prior to starting this guide.
필요한 것
Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
Lift screen off of plastic cover to expose the internal components.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
This instruction set was VERY useful, since it focused on the exact device that I have, and had great photos to accompany the steps. TC
