주요 콘텐츠로 건너뛰기
Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement
필요한 것
  1. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Screen: 1 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Screen: 1 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Screen: 1 단계, 이미지 3/3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 2 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 2 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 2 단계, 이미지 3/3
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 3 단계, 이미지 1/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 3 단계, 이미지 2/3 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 3 단계, 이미지 3/3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 4 단계, 이미지 1/1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 6 단계, 이미지 1/1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 7 단계, 이미지 1/2 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 7 단계, 이미지 2/2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
  9. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Speaker: 9 단계, 이미지 1/2 Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Identify the speakers on the upper left and right side of the inside of the device.
    • Using a Phillips 0 screwdriver, unscrew the two screws in each speaker.
  10. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 10 단계, 이미지 1/1
    • Using tweezers, unclip the speaker's wires from the device's motherboard.
  11. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 11 단계, 이미지 1/1
    • Carefully unhook the wires connecting the speakers from the hooks that hold them.
  12. Toshiba Satellite Click 2 L35W-B3204 Speaker Replacement: 12 단계, 이미지 1/1
    • The speakers are now fully removed from the device.
결론
Lexi Lannigan
회원 가입일: 10/17/18
753 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 UMass Dartmouth, Team S1-G4, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G4
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 151
