주요 콘텐츠로 건너뛰기
Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement
필요한 것
  1. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement, Heat Sync Fan: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the power connector from the fan using a pair of tweezers.
  9. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove two 3.0mm Phillips J0 screws using a Phillips screw driver.
  10. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Remove four 3.5mm Phillips J0 screws from the heat sink.
  11. Toshiba Satellite Click 2 Pro Heat Sync Fan Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the heat sink fan.
    • The heat sink cover may be hard to peel off the first time due to the adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Paul DeOrsey
회원 가입일: 03/10/16
893 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-3, Catania Spring 2016 UMass Dartmouth, Team 4-3, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 539
