주요 콘텐츠로 건너뛰기
Toshiba Satellite Click 2 Pro Wifi Card Replacement
필요한 것
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: 1 단계, 이미지 2/2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 2 단계, 이미지 1/3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 2 단계, 이미지 2/3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 2 단계, 이미지 3/3
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 3 단계, 이미지 1/2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 3 단계, 이미지 2/2
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 4 단계, 이미지 1/2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 4 단계, 이미지 2/2
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 5 단계, 이미지 1/3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 5 단계, 이미지 2/3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 5 단계, 이미지 3/3
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 6 단계, 이미지 1/2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 6 단계, 이미지 2/2
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 7 단계, 이미지 1/1
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: 8 단계, 이미지 1/1
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 9 단계, 이미지 1/1
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 10 단계, 이미지 1/1
    • Remove wifi card.
결론
Paul DeOrsey
회원 가입일: 03/10/16
893 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-3, Catania Spring 2016 UMass Dartmouth, Team 4-3, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 420
