필요한 것
Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
You don't need to remove all the screws - only the two that are directly above the battery compartment. Tried it myself!
Tengo una duda, es unicamente esta bateria la que hay que reemplazar o existe alguna bateria interna que tambien se daba reemplazar?
