주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4100 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite E45-B4100 Hard Drive Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Hard Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite E45-B4100 Hard Drive Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Be sure to use ESD-safe tools, we recommend using the iFixit Pro Tech Toolkit
  5. Toshiba Satellite E45-B4100 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite E45-B4100 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Unplug the Hard Drive from the Motherboard.
  6. Toshiba Satellite E45-B4100 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite E45-B4100 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
  7. Toshiba Satellite E45-B4100 Hard Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite E45-B4100 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
    • Remove the USB Port Circuit Board.
  8. Toshiba Satellite E45-B4100 Hard Drive Replacement: 8 단계, 이미지 1/2 Toshiba Satellite E45-B4100 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Gently remove the hard drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Delaney
회원 가입일: 10/11/16
104 평판
안내서 1개 작성함
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
By and large this and the B4200 guide are interchangeable. I followed both when reviving my B4100, as the pictures the respective authors show the components from different angle. Good stuff; thank you!
Kntai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,397
