주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4100 RAM Replacement
필요한 것
  1. Toshiba Satellite E45-B4100 RAM Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 RAM Replacement: 2 단계, 이미지 1/1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite E45-B4100 RAM Replacement: 4 단계, 이미지 2/2
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend iFixit Toolkit.
  5. Toshiba Satellite E45-B4100 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite E45-B4100 RAM Replacement: 5 단계, 이미지 2/2
    • Pull the two metal brackets out away from RAM unit while simultaneously sliding the RAM unit out.
결론
Brendan Sweeney
회원 가입일: 10/11/16
182 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 629
