주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement
필요한 것
  1. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: 2 단계, 이미지 1/1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: 3 단계, 이미지 1/3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: 3 단계, 이미지 2/3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: 3 단계, 이미지 3/3
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend the iFixit toolkit.
  4. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: 4 단계, 이미지 1/1
    • Using the #0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive and remove the USB Port Circuit Board as shown.
결론
Tori Ryals
회원 가입일: 10/11/16
41 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 392
