주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4200 RAM Replacement
필요한 것
  1. Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 1 단계, 이미지 1/3 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 1 단계, 이미지 2/3 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: 1 단계, 이미지 3/3
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 RAM Replacement, RAM: 2 단계, 이미지 1/2 Toshiba Satellite E45-B4200 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Underneath the two plastic black flaps you will find the RAM sticks.
  3. Toshiba Satellite E45-B4200 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite E45-B4200 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite E45-B4200 RAM Replacement: 3 단계, 이미지 3/3
    • To remove the RAM from the slot, pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Repeat the instructions for the other RAM slot.
결론
Raymond Makynen
회원 가입일: 03/20/23
289 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 24
전체 시간: 279
