주요 콘텐츠로 건너뛰기
Toshiba Satellite E45T-A4300 Heat Sink Replacement
필요한 것
  1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 2 단계, 이미지 1/1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Heat Sink: 3 단계, 이미지 1/1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 4 단계, 이미지 1/3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 4 단계, 이미지 2/3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 4 단계, 이미지 3/3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
결론
James Nguyen
회원 가입일: 10/23/18
573 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 229
