주요 콘텐츠로 건너뛰기
Toshiba Satellite E45T-A4300 Motherboard Replacement
필요한 것
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: 2 단계, 이미지 1/1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 5 단계, 이미지 2/2
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 6 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 6 단계, 이미지 2/2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 8 단계, 이미지 2/2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: 9 단계, 이미지 1/1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: 10 단계, 이미지 1/3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 10 단계, 이미지 2/3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 10 단계, 이미지 3/3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: 11 단계, 이미지 1/1
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: 13 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 14 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 14 단계, 이미지 2/2
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: 15 단계, 이미지 1/1
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: 16 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: 17 단계, 이미지 1/3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 17 단계, 이미지 2/3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 17 단계, 이미지 3/3
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: 18 단계, 이미지 1/2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 18 단계, 이미지 2/2
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: 19 단계, 이미지 1/1
    • Remove the motherboard from the device.
결론
James Nguyen
회원 가입일: 10/23/18
573 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 690
