주요 콘텐츠로 건너뛰기
Toshiba Satellite E45t-B4204 Fan Replacement
필요한 것
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: 1 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: 1 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: 2 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Fan Replacement: 2 단계, 이미지 2/2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: 3 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Fan Replacement: 3 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Fan Replacement: 3 단계, 이미지 3/3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: 5 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Fan Replacement: 5 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Fan Replacement: 5 단계, 이미지 3/3
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: 6 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Fan Replacement: 6 단계, 이미지 2/2
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: 7 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Fan Replacement: 7 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Fan Replacement: 7 단계, 이미지 3/3
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
결론
Perla Ruiz
회원 가입일: 03/22/18
159 평판
안내서 1개 작성함
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Sam Houston State, Team S17-G4, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 248
