주요 콘텐츠로 건너뛰기
Toshiba Satellite E45t-B4204 Keyboard Replacement
필요한 것
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 1 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 1 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 2 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 2 단계, 이미지 2/2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 3 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 3 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 3 단계, 이미지 3/3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: 4 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2/2
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 5 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 5 단계, 이미지 2/2
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 6 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 6 단계, 이미지 2/2
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 7 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 7 단계, 이미지 2/2
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 8 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 8 단계, 이미지 2/2
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 9 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 9 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 9 단계, 이미지 3/3
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 10 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 10 단계, 이미지 2/2
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 11 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 11 단계, 이미지 2/2
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 12 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 12 단계, 이미지 2/2
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 13 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 13 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 13 단계, 이미지 3/3
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 14 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 14 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 14 단계, 이미지 3/3
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 15 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 15 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 15 단계, 이미지 3/3
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 16 단계, 이미지 1/1
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 17 단계, 이미지 1/1
    • Remove the keyboard.
결론
Youdong Yan
회원 가입일: 05/22/19
229 평판
안내서 1개 작성함
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 회원
IUPUI-WILSON-SU19S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 562
