주요 콘텐츠로 건너뛰기
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
필요한 것
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 1 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 1 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 2 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 2 단계, 이미지 2/2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 3 단계, 이미지 1/3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 3 단계, 이미지 2/3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 3 단계, 이미지 3/3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: 4 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: 4 단계, 이미지 2/2
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 5 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 5 단계, 이미지 2/2
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 6 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 6 단계, 이미지 2/2
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
결론
Eduardo
회원 가입일: 03/22/18
411 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Sam Houston State, Team S17-G4, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 453
