주요 콘텐츠로 건너뛰기
Toshiba Satellite E45t-B4204 Trackpad Replacement
필요한 것
  1. Toshiba Satellite E45t-B4204 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • Remove the 15 screws holding the back panel in place with the Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Trackpad Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the laptop.
  3. Toshiba Satellite E45t-B4204 Trackpad Replacement: 3 단계, 이미지 1/1
    • Ground yourself.
    • Failure to ground yourself may result in electric shock.
  4. Toshiba Satellite E45t-B4204 Trackpad Replacement: 4 단계, 이미지 1/2 Toshiba Satellite E45t-B4204 Trackpad Replacement: 4 단계, 이미지 2/2
    • Remove speaker screws.
  5. Toshiba Satellite E45t-B4204 Trackpad Replacement: 5 단계, 이미지 1/1
    • Unplug and remove the speakers using the spudger.
  6. Toshiba Satellite E45t-B4204 Trackpad Replacement: 6 단계, 이미지 1/1
    • Remove the four screws holding the processor in place.
    • Remove the processor.
  7. Toshiba Satellite E45t-B4204 Trackpad Replacement: 7 단계, 이미지 1/1
    • Remove the heatsink.
  8. Toshiba Satellite E45t-B4204 Trackpad Replacement: 8 단계, 이미지 1/1
    • Remove the Wi-Fi card.
    • The Wi-Fi card is on the opposite side of the fan from the processor.
  9. Toshiba Satellite E45t-B4204 Trackpad Replacement: 9 단계, 이미지 1/1
    • Remove keyboard screws.
  10. Toshiba Satellite E45t-B4204 Trackpad Replacement: 10 단계, 이미지 1/1
    • Remove motherboard and attached components.
  11. Toshiba Satellite E45t-B4204 Trackpad Replacement: 11 단계, 이미지 1/1
    • Remove trackpad.
결론
Marvin Scott
회원 가입일: 05/22/19
193 평판
안내서 1개 작성함
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 회원
IUPUI-WILSON-SU19S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 252
