주요 콘텐츠로 건너뛰기
Toshiba Satellite E45t-B4300 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Bottom Case: 3 단계, 이미지 1/1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3/3
    • Use the point end of the spudger to lift the the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Use an opening tool or your fingers to lift the hard drive out of the laptop.
  9. Toshiba Satellite E45t-B4300 Hard Drive Replacement: 9 단계, 이미지 1/2 Toshiba Satellite E45t-B4300 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Unplug the hard drive from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Swanson
회원 가입일: 02/20/17
701 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G2, Sullivan Spring 2017 USF Tampa, Team S2-G2, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 2,751
