소개
This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X hard drive. Reasons the hard drive might need replacing include the hard drive making noise, not running as fast as you would like, or not as much storage as you would like. Before removing the hard drive make sure that it has been backed up so information stored on it is not lost.
필요한 것
Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
다른 한 분이 해당 안내서를 완성하였습니다.
