주요 콘텐츠로 건너뛰기
Toshiba Satellite L15W-B1208X Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 3 단계, 이미지 3/3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 4 단계, 이미지 3/3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
  5. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: 5 단계, 이미지 1/2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: 5 단계, 이미지 2/2
    • Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
  6. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 6 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 6 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 6 단계, 이미지 3/3
    • Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
    • Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
  7. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 7 단계, 이미지 3/3
    • Gently lift the soundboard out of the laptop.
  8. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: 8 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: 8 단계, 이미지 3/3
    • Pull up on the ribbon beneath the hard drive to lift the hard drive upwards.
  9. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 9 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 9 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 9 단계, 이미지 3/3
    • Gently pull the hard drive towards the edge of the laptop to disconnect the hard drive from the laptop circuitry.
  10. Toshiba Satellite L15W-B1208X Hard Drive Replacement: 10 단계, 이미지 1/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 10 단계, 이미지 2/3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: 10 단계, 이미지 3/3
    • Remove the hard drive from black rubber mount by pulling the corner of the rubber mount away from the hard drive.
    • Continue pulling the rubber mount away from the hard drive until all four corners have been taken off.
    • Pull the remainder of the rubber mount away from the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian Herbster
회원 가입일: 01/26/20
374 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 404
