주요 콘텐츠로 건너뛰기
Toshiba Satellite L15W-B1303 Charging Port Replacement
필요한 것
  1. Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: 1 단계, 이미지 1/3 Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: 1 단계, 이미지 2/3 Toshiba Satellite L15W-B1303 Charging Port Replacement, Bottom Panel: 1 단계, 이미지 3/3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Charging Port Replacement, Charging Port: 2 단계, 이미지 1/1
    • Detach the white connector from the laptop using the pointed end of a spudger.
  3. Toshiba Satellite L15W-B1303 Charging Port Replacement: 3 단계, 이미지 1/1
    • Once the port has been disconnected, carefully lift the whole charging port off the panel.
결론
Alejandro Oliveros
회원 가입일: 01/29/20
85 평판
안내서 1개 작성함
York University, Team S8-G2, Turner Winter 2020 York University, Team S8-G2, Turner Winter 2020 회원
YORK-TURNER-W20S8G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 183
