주요 콘텐츠로 건너뛰기
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
필요한 것
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 1 단계, 이미지 1/3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 1 단계, 이미지 2/3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 1 단계, 이미지 3/3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 2 단계, 이미지 1/3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 2 단계, 이미지 2/3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 2 단계, 이미지 3/3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: 3 단계, 이미지 1/1
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: 4 단계, 이미지 1/1
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: 5 단계, 이미지 1/1
    • Remove the board from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Yanchen Li
회원 가입일: 01/22/20
121 평판
안내서 1개 작성함
York University, Team S8-G2, Turner Winter 2020 York University, Team S8-G2, Turner Winter 2020 회원
YORK-TURNER-W20S8G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 280
