주요 콘텐츠로 건너뛰기
위험
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
위험
소개
Welcome to the Toshiba Satellite L305-S5875 CCFL Tube Replacement guide page. This guide uses both visual and written instructions in a step by step manner to help you replace the damaged CCFL tube in your screen with a brand new one.
  1. Open the laptop so that you can see the screen.
    • Open the laptop so that you can see the screen.
  2. Remove the four rubber inserts from the four corners of the screen. Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop. Gently pull the back panel approximately 1 inch away from the screen. Warning: Following step will detach screen from casing. Use caution.
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Lay screen down on keyboard. On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present. Carefully remove the ribbon cable by pulling it out of it's socket.
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  6. At the bottom of the screen, locate the pink and white wires. Unplug the connector from the circuit board by gently pulling it out. Unplug the connector from the circuit board by gently pulling it out.
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  7. Congratulations, you have just removed your screen!
    • Congratulations, you have just removed your screen!
  8. With the screen now removed from the computer, remove the two screws from the screen's metal enclosure. In addition to removing the screws, remove the tape on the edge of the screen.
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  9. Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure. Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube. Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  10. With the bad CCFL tube now accessible, very carefully remove it from the screen housing. With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 2014년 03월 11일
208 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 회원
UMASSD-CALAWAY-S14S3G1
4 회원들
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 349
