주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5875 Hinge Replacement
필요한 것
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 1 단계, 이미지 3/3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: 2 단계, 이미지 1/1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Hinge Replacement: 3 단계, 이미지 2/2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Hinge Replacement: 4 단계, 이미지 2/2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: 5 단계, 이미지 1/1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 6 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 6 단계, 이미지 2/2
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: 7 단계, 이미지 1/1
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: 8 단계, 이미지 1/1
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: 9 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Hinge Replacement: 9 단계, 이미지 2/2
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 03/11/14
208 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 회원
UMASSD-CALAWAY-S14S3G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Will this work for a Toshiba satellite l655 model
ethanhunemuller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 6,425
