주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5875 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite L305-S5875 Keyboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite L305-S5875 Keyboard Replacement: 2 단계, 이미지 3/3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Keyboard Replacement: 5 단계, 이미지 2/2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L305-S5875 Keyboard Replacement: 6 단계, 이미지 2/2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: 7 단계, 이미지 1/1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
결론
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
다른 3명이 해당 안내서를 완성하였습니다.
Juan
회원 가입일: 01/11/13
109 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 회원
CPSU-MANESS-W13S20G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
It's not so easy to do step 3.
Texas Chick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,189
