이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your keyboard is damaged or not working properly, it is fairly easy to replace.
필요한 것
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard.
Using your fingers, remove this long piece of plastic gently.
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
다른 3명이 해당 안내서를 완성하였습니다.
